Hi, i am trying to install dnscrypt on DietPi.
I follow all steps on pihole wiki about dnscrypt.
But dnscrypt faile to start.
I got no dnscrypt running
root@DietPi:~# ps ax | grep dnscrypt
1914 pts/0 S+ 0:00 grep dnscrypt
the service is enable but it fails to start
root@DietPi:~# sudo systemctl status -l dnscrypt-proxy@*
● dnscrypt-proxy@adguard-dns-family-ns1.service - DNSCrypt client proxy
Loaded: loaded (/lib/systemd/system/dnscrypt-proxy@.service; enabled)
Active: failed (Result: start-limit) since Sat 2017-05-27 12:08:37 BST; 48s ago
Docs: man:dnscrypt-proxy(8)
Process: 807 ExecStart=/usr/local/sbin/dnscrypt-proxy --resolver-name=%i --user=dnscrypt (code=exited, status=1/FAILURE)
Main PID: 807 (code=exited, status=1/FAILURE)
May 27 12:08:37 DietPi systemd[1]: Unit dnscrypt-proxy@adguard-dns-family-ns1.service entered failed state.
May 27 12:08:37 DietPi systemd[1]: dnscrypt-proxy@adguard-dns-family-ns1.service holdoff time over, scheduling restart.
May 27 12:08:37 DietPi systemd[1]: Stopping DNSCrypt client proxy...
May 27 12:08:37 DietPi systemd[1]: Starting DNSCrypt client proxy...
May 27 12:08:37 DietPi systemd[1]: dnscrypt-proxy@adguard-dns-family-ns1.service start request repeated too quickly, refusing to start.
May 27 12:08:37 DietPi systemd[1]: Failed to start DNSCrypt client proxy.
Were you able to resolve this, or are you still having issues. Sorry for not seeing this earlier.
I have the same issue on my Raspberry 3 with Raspbian.
I followed the wiki.
pi@raspberrypi:~ $ sudo systemctl status -l dnscrypt-proxy@*
● dnscrypt-proxy@dnscrypt.eu-nl.service - DNSCrypt client proxy
Loaded: loaded (/etc/systemd/system/dnscrypt-proxy@.service; enabled)
Active: failed (Result: start-limit) since Tue 2017-07-18 20:19:56 CEST; 48s ago
Process: 810 ExecStart=/usr/local/sbin/dnscrypt-proxy (code=exited, status=1/FAILURE)
Main PID: 810 (code=exited, status=1/FAILURE)
Jul 18 20:19:55 raspberrypi dnscrypt-proxy[810]: Tue Jul 18 20:19:55 2017 [ERROR] Example: dnscrypt-proxy /usr/local/etc/dnscrypt-proxy.conf
Jul 18 20:19:55 raspberrypi dnscrypt-proxy[810]: Tue Jul 18 20:19:55 2017 [ERROR] The local list of public resolvers is loaded from: [/usr/local/share/dnscrypt-proxy/dnscrypt-resolvers.csv]
Jul 18 20:19:55 raspberrypi dnscrypt-proxy[810]: Tue Jul 18 20:19:55 2017 [ERROR] Consult https://dnscrypt.org for more information about dnscrypt-proxy.
Jul 18 20:19:55 raspberrypi systemd[1]: Unit dnscrypt-proxy@dnscrypt.eu-nl.service entered failed state.
Jul 18 20:19:56 raspberrypi systemd[1]: dnscrypt-proxy@dnscrypt.eu-nl.service holdoff time over, scheduling restart.
Jul 18 20:19:56 raspberrypi systemd[1]: Stopping DNSCrypt client proxy...
Jul 18 20:19:56 raspberrypi systemd[1]: Starting DNSCrypt client proxy...
Jul 18 20:19:56 raspberrypi systemd[1]: dnscrypt-proxy@dnscrypt.eu-nl.service start request repeated too quickly, refusing to start.
Jul 18 20:19:56 raspberrypi systemd[1]: Failed to start DNSCrypt client proxy.
Jul 18 20:19:56 raspberrypi systemd[1]: Unit dnscrypt-proxy@dnscrypt.eu-nl.service entered failed state.
