*** [ DIAGNOSING ]: contents of /etc/lighttpd/conf.d /etc/lighttpd/conf.d does not exist
The issue I am facing:
*** [ DIAGNOSING ]: contents of /etc/lighttpd/conf.d /etc/lighttpd/conf.d does not exist.
I can't update the gravity list. Only updates the one that comes by default.
I think I could have a language problem.
Details about my system:
Raspberry pi 4 B 8GB
Spain.
Nothing.
Tools > Generate Debug Log
https://tricorder.pi-hole.net/XaT8Ahn0/
Thank you for your help.
The message below is expected on Debian and derivative Operating Systems:
This is not an issue.
How did you try to update gravity? Using the web interface or on the command line?
Did you receive any error message?
I've tried both, web and command line.
No error in both.
In WEB, I added like several lists and then went to tools/ gravity/update.
The update just showed me every time the update of the List by default and didn't take the new ones added.
In command line, no message at all.
Sometime trying it it looked like the connection with pihole was interrupted as I couldn't browse internet nore pihole interface.
Thank you
Please post the complete output of pihole -g
Don't ask me why. Now command line it worked.
Posting it.
Even I see blocked traffic in the dashboard I keep seeing Ads from youtube...
After seeing that it was working, I've added more domains and executed again pihole -g
Rasp Pi fried. Again.
after 1 min it came back
I had to access again the SSH and executed again pihole -g
"DNS resolution is currently unavailable"
Internet traffic isn't working at all.
Finally after 3 min internet came back.
Screenshot from 2023-03-14 15-20-57
Pi-hole won't reliably block YT ads. The ads are served from the same domains as the content.
Please upload a new debug log and post the new token.
https://tricorder.pi-hole.net/LK5hL9nK/
Thank you for your help. do you see something weird?
This debug log shows no problems. Pi-hole is working properly. It is receiving DNS queries, filtering them, forwarding as needed to upstream DNS servers and replying with IP's.
[✓] www.vinted-pl-gj32d.gameikan.live is 0.0.0.0 on lo (127.0.0.1)
[✓] www.vinted-pl-gj32d.gameikan.live is 0.0.0.0 on eth0 (192.168.1.164)
[✓] www.vinted-pl-gj32d.gameikan.live is 0.0.0.0 on wlan0 (192.168.1.163)
[✓] doubleclick.com is 142.250.200.142 via a remote, public DNS server (8.8.8.8)
   Mar 14 14:31:17 dnsmasq[624]: query[A] api.snapcraft.io from 192.168.1.134
   Mar 14 14:31:17 dnsmasq[624]: forwarded api.snapcraft.io to 1.1.1.1
   Mar 14 14:31:17 dnsmasq[624]: query[AAAA] api.snapcraft.io from 192.168.1.134
   Mar 14 14:31:17 dnsmasq[624]: reply api.snapcraft.io is NODATA-IPv6
   Mar 14 14:31:18 dnsmasq[624]: reply api.snapcraft.io is 185.125.188.59
   Mar 14 14:31:18 dnsmasq[624]: reply api.snapcraft.io is 185.125.188.54
   Mar 14 14:31:18 dnsmasq[624]: reply api.snapcraft.io is 185.125.188.55
   Mar 14 14:31:18 dnsmasq[624]: reply api.snapcraft.io is 185.125.188.58
Is there a reason you have two active interfaces on the Pi? This doesn't appear to be causing a problem, but for Pi-hole purposes you only need the eth0 interface active.
    PIHOLE_INTERFACE=eth0
No I don't it's because I have ethernet and Wifi...
I guess I should de-activate the wifi.
Let me do it.
thank you for the heads up.
Although, updates are not working as I'm seeing everyone, like going inside the adlist, adding the domains list and then upgrade gravity with no issues. Every time I try it, I have problems...
Done
https://tricorder.pi-hole.net/TYEYMFpR/
Again I've got myself stuck here.
I can't have the Adlist grow over the default 188K from the default adlist...
Now finally it did!!!
Doing the same steps but deleting first the old ones.
weird.
