Hi!
I am experiencing issues with my DHCP server which is set up on my RBP.
Connect to WiFi from the laptop works with automatic settings, thanks to DHCP.
Cannot get address unless I set up IP, mask, gateway and DNS manually.
More info
- LAN: 10.7.0.0/24;
- Gateway is a Netgear RAX80 on 10.7.0.1;
- RPB4 8 Gb with Raspberry Pi OS Lite (32 bit) is on 10.7.0.1;
- Upstream DNS: cloudflared on 127.0.0.1:53000;
- I have disabled DHCP on my router and activated it on Pihole;
- It seems the DHCP is discoverable on the network when running
nmap --script broadcast-dhcp-discover -e wlan0
on my laptop: see output below;
- Firewall: nftables.
Config
Debug token: https://tricorder.pi-hole.net/4i39jsoc84
/etc/nftables.conf: pastebin.com/5Nrgbq4k
/etc/cloudflared/config.yml: pastebin.com/7b4n0Tre
/etc/pihole/setupVars.conf: pastebin.com/D8AqUNjf
/etc/dhcpcd.conf: pastebin.com/qAHHDYY3
nmap discover
: pastebin.com/twFXi4Nr
Have a nice day!
hermesd
The debug log shows that DHCP is working:
Timeout: 10 seconds
WARN: Could not sendto() in send_dhcp_discover() (/root/project/src/dhcp-discover.c:223): Network is unreachable
* Received 300 bytes from eth0:10.7.0.2
Offered IP address: 10.7.0.153
Server IP address: 10.7.0.2
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 10.7.0.2
lease-time: 86400 ( 1d )
renewal-time: 43200 ( 12h )
rebinding-time: 75600 ( 21h )
netmask: 255.255.255.0
broadcast: 10.7.0.255
dns-server: 10.7.0.2
domain-name: "hermes"
router: 10.7.0.1
--- end of options ---
DHCP packets received on interface wlan0: 0
Hello, thank you for your reply.
I solved the issue by adding the following line /etc/nftables.conf
udp sport bootpc udp dport bootps ip saddr 0.0.0.0 ip daddr 255.255.255.255 accept comment "Accept DHCPDISCOVER (for DHCP-Proxy)"
system
Closed
7
