IP addresses allocated on network.
DNS works fine but no DHCP server.
https://tricorder.pi-hole.net/99czcsnlh6
I'm running PiHole in docker, previously ran DHCP server fine with
--NET=host
due to a port conflict with Nginx I'm trying to allocate only the ports I need so I can free up 80. My docker run script is now:
docker run -d \
--name pihole \
-p "53:53/tcp" \
-p "53:53/udp" \
-p "67:67" \
-p "68:68" \
-p "80:80/tcp" \
-p "443:443/tcp" \
-v "/home/meatalhead/pihole/:/etc/pihole/" \
-v "/etc/dnsmasq.d/:/etc/dnsmasq.d/" \
-e ServerIP="192.168.1.68/24" \
-e VIRTUAL_HOST="pi.hole" \
-e PROXY_LOCATION="pi.hole" \
-e TZ="Europe/London" \
--restart=unless-stopped \
--dns 127.0.0.1 \
--cap-add NET_ADMIN \
pihole/pihole:latest
My debug log is saying: Error: Neither IPv4 or IPv6 selected
and
192.168.1.68/24 does not match the IP found in /etc/pihole/setupVars.conf
The contents of /etc/pihole/setupVars.conf:
DNS_BOGUS_PRIV=
DNS_FQDN_REQUIRED=
DNSSEC=
CONDITIONAL_FORWARDING=
CONDITIONAL_FORWARDING_IP=
CONDITIONAL_FORWARDING_DOMAIN=
CONDITIONAL_FORWARDING_REVERSE=
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
PIHOLE_INTERFACE=eth0
Has anyone else got PiHole in docker with DHCP running and not using --NET=Host
