Replace this text with what you think should be happening. Please include as much detail relevant to your system/install as possible including, but not limited to:
- Operating System (Family and Version)
- Hardware
- Docker compose file or Docker run command
- Docker engine version
Replace this text with what is actually happening
Replace this text with the debug token provided from running https://tricorder.pi-hole.net/WAnJjfBc/
