Also this is output from netstat - dont know if that helps.
sudo netstat -anlp | grep -w LISTEN
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 3314/pihole-FTL
tcp 0 0 0.0.0.0:801 0.0.0.0:* LISTEN 2643/lighttpd
tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 3314/pihole-FTL
I ended up with flushing my iptables totally, and now it works... some rule was blocking it I guess...
Now for a more "simple" firewall.
DL6ER
24
Maybe I have missed something here, but
alone might just have been insufficient. Note that you also need to configure that the Pi-hole can actually reply to your clients (proper OUT rules).
I guess, I'm no expert on firewalls
Thank you for the help! How do I close this thread?
Mcat12
26
It has been marked as solved.
system
Closed
27
