The dashboard should show top clients, queries, etc
All the dashboard dials are at zero except "Domains on Blocklist". Pihole is running DHCP server, all clients resolve an IP from pihole with correct DNS, ads are blocked on all devices as they should be. There is just no log of how much the pihole is blocking.
t01uoak541
DL6ER
June 13, 2018, 8:56am
2
What's the output when you run
echo ">stats" | nc 127.0.0.1 4711
on your Pi-hole?
pi@raspberrypi:~ $ echo ">stats" | nc 127.0.0.1 4711
domains_being_blocked 125586
dns_queries_today 0
ads_blocked_today 0
ads_percentage_today 0.000000
unique_domains 0
queries_forwarded 0
queries_cached 0
clients_ever_seen 0
unique_clients 0
status enabled
---EOM---
Is that good?
RamSet
June 13, 2018, 5:32pm
4
Maxolon:
Is that good?
That looks good. It also looks like no DNS queries were processed.
How do you use the Pi-hole DNS? Did you manually specify the Pi-hole IP as your DNS server on your clients or do you use Pi-hole as your DHCP server?
What's the output of
nslookup flurry.com
and then the same echo ">stats" | nc 127.0.0.1 4711
Mcat12
June 13, 2018, 10:09pm
5
There aren't any queries in the log since 12am this morning. Try restarting dnsmasq:
sudo service dnsmasq restart
Pihole runs DHCP. I have a standard network set up, except that I am running meraki switch and AP. They are set to work as basic L2 devices with no fancy features enabled, but I cant help but think they are blocking something.
pi@raspberrypi:~ $ nslookup flurry.com
Server: 127.0.0.1
Address: 127.0.0.1#53
Address: 192.168.20.253
dns_queries_today 0
ads_blocked_today 0
unique_domains 0
queries_forwarded 0
queries_cached 0
clients_ever_seen 0
unique_clients 0
status enabled
---EOM---
Ran the command, no change in logs. When I go to Block Ads! Adblock test it tells me ads are blocked.
Your debug token is: yn2ig3od1n
Mcat12
June 17, 2018, 1:11am
10
Your dnsmasq config file does not have the correct settings for FTL to be able to read the log.
Run pihole -r
to repair and it should fix it.
Thanks, that worked after a fashion.
I ran pihole -r for no effect, then I ran apt-get update and apt-get upgrade, then pihole -r again. My counters started changing straight away.
Thanks again!
DanSchaper
Split this topic
June 21, 2018, 3:30pm
12
A post was split to a new topic: Dnsmasq.service not starting
system
Closed
July 12, 2018, 3:39pm
13
