Dashboard completely empty
I expect to see the ususal graphs (Total queries, Client Activity, Query Types, and so on, under the the four colored areas called Total Queries, Queries Blocked, Percentage Blocked, Domains on Blocklist.
Absolutely nothing is shown below those four colored areas, and the four colored areas themselves contain no data except for their titles. In other words, there is no count of Total queries, Queries Blocked, and so on.
https://tricorder.pi-hole.net/KejNRAPh
PiHole works fine, the logs are populated by blocked and not-blocked requests. All other pages of the Admin panel work fine, including Querying the logs. I have checked permissions on files in /var/log, I have re-configured the installation, but nothing worked. I have NOT flushed the logs. PiHole also works as DHCP server.
Pi-hole version is v5.5 (Latest: v5.5)
AdminLTE version is v5.7 (Latest: v5.7)
FTL version is v5.10.2 (Latest: v5.10.2)
Ubuntu Server 20.04.3 LTS Focal
Intel NUC8i3BEH
(I have three PiHole installs: two run on lxc containers, and work perfectly, the only un-virtualized one is this giving me a small problem).
Apache is on port 80 and preventing lighttpd from binding.
[80] is in use by apache2 (https://docs.pi-hole.net/main/prerequisites/#ports)
How true, and how embarrassing. But any rate, thanks for taking a look at it.
JJ
