would be great if we would have the option in the web interface (maby under advanced) to toggle mor custom DNS upstream IPv4 and IPv6
would be great if you could put it in the dev
thanks
thanks
AFAIK, it will support as many as you want to put in there, but currently you need to do that manually by adding them to /etc/pihole/setupVars.conf
Not a bad idea though!
thanks for the fast awnser!!
would be great
Hi, what is a costume DNS upstream?
if you go to the web interface under tetings scroll down you see DNS upstream the custom is if i want to use an other DNS server than pihole offers you
I'm assuming spelling mistake for "custom"
ah im sorry XD still learning
Implemented.
