Dear helper,
I got a problem
Problem:
_pi@raspberrypi:~ $ sudo curl -sSL https://install.pi-hole.net | bash
curl: (6) Could not resolve host: install.pi-hole.net
_
Could you guys help me?
I did set up a static IP Adress and all other stuff.
Kind Regards,
SleinEater / Niels
jfb
2
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1
to nameserver 9.9.9.9
or your preferred third party DNS service, save and exit
Run the install script again: curl -sSL https://install.pi-hole.net | bash
it's working already after a complete reinstall of raspbian.
system
Closed
6
