Ich bin mit dem Pi-hole nach langem testen endlich auf dem endgültigem Sstem angekommen. Pi-Hole läuft jetzt bei mir auf einem NUC5 mit Debian 9.
Nun möchte ich die automatischen Updates einrichten, komme jedoch nicht weiter...
Inhalt der /etc/cron.d/pihole
- Update und Flush ausgeschaltet:
# Updates ad sources every week
# This file is under source-control of the Pi-hole installation and update
# scripts, any changes made to this file will be overwritten when the softare
# is updated or re-installed. Please make any changes to the appropriate crontab
# or other cron file snippets.
# Pi-hole: Update the ad sources once a week on Sunday at a random time in the
# early morning. Download any updates from the adlists
# 9 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
# Pi-hole: Flush the log daily at 00:00
# The flush script will use logrotate if available
# parameter "once": logrotate only once (default is twice)
# parameter "quiet": don't print messages
# 00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
# @reboot root /usr/sbin/logrotate /etc/pihole/logrotate
# Pi-hole: Grab local version and branch every 10 minutes
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
# Pi-hole: Grab remote version every 24 hours
32 14 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
Richtig so?
und "Inhalt" von crontab -e
um als root Pi-hole, Listen und Debian aktuell zu halten
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h dom mon dow command
0 2 * * * pihole -g
0 1 * * 3 pihole -up
0 3 */7 * * sudo apt-get clean && sudo apt-get update && sudo apt-get -y upgrade && sudo apt-get autoclean && sudo apt-get -y autoremove && sudo reboot now
0 4 */14 * * sudo apt-get clean && sudo apt-get update && sudo apt-get -y dist-upgrade && sudo apt-get autoclean && sudo apt-get -y autoremove && sudo reboot now
Stimmen die alle so?
