Problem with Beta 5.0:
When I convert a DHCP lease to static a PHP error is shown:
There was a problem applying your settings.
Debugging information:
PHP error (2): fopen(/etc/dnsmasq.d/04-pihole-static-dhcp.conf): failed to open stream: No such file or directory in /var/www/html/admin/scripts/pi-hole/php/savesettings.php:84
Clean install of Beta 5 on a fresh Debian Buster VM.
Pi-hole Version vDev (release/v5.0, v4.3.2-419-gee7090b) Web Interface Version vDev (release/v5.0, v4.3.2-424-ge169bec9) FTL Version vDev (release/v5.0, vDev-ff840d0)
What are the permissions on the files in that directory? sudo ls -lach /etc/dnsmasq.d
It looks like you have imported data from a previous installation, via teleporter? What was the previous version and does the problem happen with a fresh install and no importing of previous data?
Well, "these instructions" were explicitly labeled as being untested and experimental. I do not recall where I put them up, however, there should be enough posts like "does not really work" below...
drwxr-xr-x 2 root root 4,0K Feb 18 22:16 .
drwxr-xr-x 82 root root 4,0K Feb 18 22:06 ..
-rw-r--r-- 1 root root 1,7K Feb 18 22:06 01-pihole.conf
-rw-r--r-- 1 root root 668 Feb 18 22:06 02-pihole-dhcp.conf
-rw-r--r-- 1 root root 53 Feb 18 22:16 04-pihole-static-dhcp.conf
Yes, but only the Black- and Whitelists.
There was no previous installation on this system. It was a fresh installation from scratch on Debian 10. Or do you mean the system from where I imported the data via teleporter? That was:
Pi-Hole Version v4.3.2
Web Interface: v4.3.2
FTL version: v4.3.1
Generally said the installation works. It's only the previously mentioned error I encountered when I try to convert a DHCP lease to static.
Hi, I have the same issue but with the current release:
Pi-hole version is v4.3.2 (Latest: v4.3.2)
AdminLTE version is v4.3.3 (Latest: v4.3.3)
FTL version is v4.3.1 (Latest: v4.3.1)
Setup on a PI 4 Model B with Ubuntu 19.10
I get the same results as cwt (can't use@) for the troubleshooting
The savesettings.php has the correct entry
Pi-hole 5.0 here. Upgrade from 4.3.5 and I have the same issue. That was an in-place migration.
History:
Pi-hole 4.3.5 with DHCP disabled (enabled on the OPNsense)
Migration to Pi-hole 5.0
Enable DHCP (and disabled it on the OPNsense)
I tried to shift an active DHCP lease to a static lease and got the same issue:
After a refresh the targeted computer has been shifted to static leases.
