patryk
March 28, 2026, 1:34am
1
I am honestly getting frustrated as my Pihole just stops working, My whole network points to it and i know when it goes down when i have no network.
I finally was able to do the pihole -d before rebooting it.
A reboot fixes it each time, I thought it was overheating so i added a fan but clearly thats not the issue.
I did have a post previously but had now replies so Iām going to try again before giving up on this box.
Thoughts and help please
0DnxDOMr
Looks like FTL crashed at least once:
2026-03-27 05:54:19.110 CDT [43962/T43997] INFO: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2026-03-27 05:54:19.110 CDT [43962/T43997] INFO: ----------------------------> FTL crashed! <----------------------------
The debug log shows only a few lines, but we can't see the crash details. We need more information.
Can you please run sudo cat /var/log/pihole/FTL.log | pihole tricorder, upload the file when asked and post here the new Token?
patryk
March 28, 2026, 11:53am
4
here is the new token: nqOn1X75
whats odd is i have had this pi4 for a while with no issues, then I started having some slowness and with the big update it was recommended to do a full clean install which i did. Was working fine for a while and then about once a week it would stop working again.
Try some stresstesting tools to see if it will crash or not.
Could be bad RAM or your Power Adapter having issues so check for Undervoltage Notifications too : raspberry pi os undervoltage at DuckDuckGo
patryk
March 30, 2026, 2:13pm
6
I was originally thinking that it was due to the network being overloaded. This only happens overnight or towards the end of the night where we have the least amount of traffic.
No voltage issues but ill check the RAM when work is done. Thanks
patryk
April 12, 2026, 4:57pm
7
Alrighty it happened again today randomly, here is my debug NFDmdQzb
please help.
i ran the debug before rebooting this time
patryk
April 14, 2026, 9:17pm
9
Happened again . I have 2 codes this time
jteoe3jF
LUGtpmTN
@DL6ER
Can you please take a look on these logs?
I'm guessing here, but apparently FTL is crashing when the certificate is generated.
@patryk
Do you access the web interface via http or https?
As a test, can you please change FTL options to only use HTTP (80) port and check if the issue still happens?
Use this command to change the port:
sudo pihole-FTL --config webserver.port '80o,[::]:80o'
Does the crash still happen?
patryk
April 15, 2026, 12:20pm
11
I applied this setting, ill keep monitoring . thanks
as of applying this setting 19 days ago i have not had issues. assuming i have to keep applying this with each update on the pihole ? Thanks again
Pi-hole configuration persists across restarts/updates. It sort of has to.
No need.
Pi-hole settings are not touched on updates.
