Debug log: https://tricorder.pi-hole.net/kf56iqkm82
Experiencing very frequent DNS resolution errors.
Youre debug log shows that Pi-hole is working. However, your DHCP server (the router) is passing its own IP as the DNS server, and not the IP of Pi-hole. This may not be related to your problem, but it's not the correct response from the DHCP server if you want all your devices to use Pi-hole.
The DHCP discovery also shows a network connectivity issue. This may be related to your problem.
Timeout: 10 seconds
WARN: Could not sendto() in send_dhcp_discover() (/root/project/src/dhcp-discover.c:223): Network is unreachable
* Received 300 bytes from eth0:192.168.86.1
Offered IP address: 192.168.86.173
Server IP address: 192.168.86.1
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.86.1
lease-time: 86400 ( 1d )
renewal-time: 43200 ( 12h )
rebinding-time: 75600 ( 21h )
netmask: 255.255.255.0
broadcast: 192.168.86.255
router: 192.168.86.1
domain-name: "lan"
dns-server: 192.168.86.1
--- end of options ---
DHCP packets received on interface wlan0: 0
Just confirmed and my router (Google Wifi) is set to use the Pi-hole (192.168.86.2) in its DNS settings. Any suggestions or caveats with regards to Google Wifi to be aware of?
If you run a new debug log and look at the DHCP section, is this the actual DNS that the router is providing to clients?
One thing that I noticed is that the DNS pool on the Google Wifi was 192.168.86.20-.250 and the static IP that I'd set on the Pihole was 192.168.86.2, which was outside the DNS pool. I have adjusted the static IP address to 192.168.86.100 to see if that helps.
Updated debug log:
https://tricorder.pi-hole.net/6mg6lwhph9
