Confused about PiHole documentation to save logs for longer than 10 minutes
#1
Show logs older than 10 minutes
Shows logs from only 10 minutes ago or older
https://tricorder.pi-hole.net/lm7dk0ohap
#2
It looks like your web interface files have been changed or modified from the original version installed by Pi-hole.
What is the results of
cd /var/www/html/admin
sudo git status
#3
Everything else looks to be set as default to show 24 hours.
   [2019-05-11 15:34:32.368 1371] ########## FTL started! ##########
   [2019-05-11 15:34:32.368 1371] FTL branch: master
   [2019-05-11 15:34:32.368 1371] FTL version: v4.2.3
   [2019-05-11 15:34:32.368 1371] FTL commit: aae487e
   [2019-05-11 15:34:32.368 1371] FTL date: 2019-02-25 17:18:14 -0800
   [2019-05-11 15:34:32.368 1371] FTL user: pihole
   [2019-05-11 15:34:32.369 1371] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
   [2019-05-11 15:34:32.369 1371]    SOCKET_LISTENING: only local
   [2019-05-11 15:34:32.369 1371]    AAAA_QUERY_ANALYSIS: Show AAAA queries
   [2019-05-11 15:34:32.369 1371]    MAXDBDAYS: max age for stored queries is 365 days
   [2019-05-11 15:34:32.369 1371]    RESOLVE_IPV6: Resolve IPv6 addresses
   [2019-05-11 15:34:32.369 1371]    RESOLVE_IPV4: Resolve IPv4 addresses
   [2019-05-11 15:34:32.369 1371]    DBINTERVAL: saving to DB file every minute
   [2019-05-11 15:34:32.369 1371]    DBFILE: Using /etc/pihole/pihole-FTL.db
   [2019-05-11 15:34:32.369 1371]    MAXLOGAGE: Importing up to 24.0 hours of log data
   [2019-05-11 15:34:32.369 1371]    PRIVACYLEVEL: Set to 0
   [2019-05-11 15:34:32.369 1371]    IGNORE_LOCALHOST: Show queries from localhost
   [2019-05-11 15:34:32.369 1371]    BLOCKINGMODE: Null IPs for blocked domains
   [2019-05-11 15:34:32.369 1371]    REGEX_DEBUGMODE: Inactive
   [2019-05-11 15:34:32.369 1371]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
   [2019-05-11 15:34:32.369 1371]    DBIMPORT: Importing history from database
   [2019-05-11 15:34:32.369 1371]    PIDFILE: Using /var/run/pihole-FTL.pid
   [2019-05-11 15:34:32.369 1371]    PORTFILE: Using /var/run/pihole-FTL.port
   [2019-05-11 15:34:32.369 1371]    SOCKETFILE: Using /var/run/pihole/FTL.sock
   [2019-05-11 15:34:32.369 1371]    WHITELISTFILE: Using /etc/pihole/whitelist.txt
#4
@UNlDAN Is this your post?
See my reply there.
