Conditional Forwarding and Split Horizon DNS
Environment
  • Running on Debian 12 LXC container on Proxmox
  • Version Details:
    • Core: 6.2.2
    • FTL: 6.3.3
    • Web Interface: 6.3
I have pi-hole running on a Debian LXC. Currently it works well, but I have one situation where I cannot make it work.
I have multiple internal networks, but I have a split at /16 (10.1.X.X and 10.2.X.X). For the 10.1.X.X network, I would like requests to be forwarded DNS servers for all queries against my domain, and for 10.2.X.X, I would like them to forward to an external address, such as Cloudflare.
  • 10.1.1.2 → Pi-Hole → Windows Internal DNS
  • 10.2.1.2 → Pi-Hole → 1.1.1.1
I have tried a few different conditional forwarding rules, but none seem to work, and I feel like I am just missing something.
I have configured these under the advanced serttings --> Conditional forwarding section of https:///admin/settings/dns.
true,10.1.0.0/16,10.1.10.20#53,domain.local
true,10.2.0.0/16,1.1.1.1#53,domain.local
Instead of sending traffic from the 10.2.X.X devices out to cloudflare, all traffic for my internal domains are being sent to the internal DNS servers.
https://tricorder.pi-hole.net/c0U2MKue/
I dont have a quick solution but ... CF consists of two parts.
One part for forward lookups (name to IP) and one part for reverse lookups (IP to name).
Above bit instructs forward lookups for the domain: domain.local to be forwarded to DNS server 10.1.10.20.
And reverse lookups for the 10.1.0.0/16 addresses to be forwarded to also 10.1.10.20.
Forward lookup example with 10.0.0.2 being my Pi-hole:
$ dig +short @10.0.0.2 hak01
10.0.0.145
Reverse lookup example:
$ dig +short @10.0.0.2 -x 10.0.0.145
hak01.home.dehakkelaar.nl.
From above, not sure if you can split up the domain: domain.local into two subnets with embedded dnsmasq like above.
I suspect dnsmasq will pick the first or last one only from above two directives.
Try changing the order to play around and follow the logs live to see what happens when testing:
sudo pihole tail
Above only deals with reverse lookups and not the forward lookups for domain.local!
Ps. about the .local search/suffix domain above:
Thank you for the detailed response. I think this clarifies it for me, and what I am trying to do is not possible. I understood this to work a bit differently from how it actually does.
I thought this would identify IP addresses of clients from the first IP (range) and forward to the second IP. Now that I understand that the first is a reverse lookup forward, this makes sense. I think my next step is to set up a second pi-hole server to manage the 10.2.x.x subnets.
As for the .local, I should have clarified that was an example. My domain in question is a .xyz domain.
I hope you have a good weekend.
No it doesnt identify the clients IP.
It only looks at the type of queries.
Type A or AAAA record queries for forward lookups.
And PTR queries for reverse lookups.
Have a good weekend!
