Cloudflared vs. unbound as upstream DNS? And Unbound installation issues
pi@raspberry:/etc/unbound $ stat /etc/unbound/unbound.conf
stat: cannot stat '/etc/unbound/unbound.conf': No such file or directory
ls -la
pi@raspberry:/etc/unbound $ ls -la
total 28
drwxr-xr-x   3 root root 4096 Oct 19 01:57 .
drwxr-xr-x 122 root root 4096 Oct 19 01:17 ..
drwxr-xr-x   2 root root 4096 Oct 19 01:54 unbound.conf.d
-rw-r-----   1 root root 2455 Oct 19 01:16 unbound_control.key
-rw-r-----   1 root root 1342 Oct 19 01:16 unbound_control.pem
-rw-r-----   1 root root 2455 Oct 19 01:16 unbound_server.key
-rw-r-----   1 root root 1334 Oct 19 01:16 unbound_server.pem
journalctl -u unbound | tail -30
pi@raspberry:/etc/unbound $ journalctl -u unbound | tail -30
Oct 19 01:54:08 raspberry systemd[1]: Stopped Unbound DNS server.
Oct 19 01:54:08 raspberry systemd[1]: Starting Unbound DNS server...
Oct 19 01:54:08 raspberry package-helper[9261]: [1603032848] unbound-checkconf[9263:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Oct 19 01:54:08 raspberry package-helper[9264]: [1603032848] unbound-checkconf[9266:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Oct 19 01:54:08 raspberry unbound[9267]: [1603032848] unbound[9267:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Oct 19 01:54:08 raspberry unbound[9267]: [1603032848] unbound[9267:0] warning: Continuing with default config settings
Oct 19 01:54:08 raspberry unbound[9267]: [1603032848] unbound[9267:0] error: can't bind socket: Address already in use for ::1 port 53
Oct 19 01:54:08 raspberry unbound[9267]: [1603032848] unbound[9267:0] fatal error: could not open ports
Oct 19 01:54:08 raspberry systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 01:54:08 raspberry systemd[1]: unbound.service: Failed with result 'exit-code'.
Oct 19 01:54:09 raspberry systemd[1]: Failed to start Unbound DNS server.
Oct 19 01:54:09 raspberry systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Oct 19 01:54:09 raspberry systemd[1]: unbound.service: Scheduled restart job, restart counter is at 9.
Oct 19 01:54:09 raspberry systemd[1]: Stopped Unbound DNS server.
Oct 19 01:54:09 raspberry systemd[1]: Starting Unbound DNS server...
Oct 19 01:54:09 raspberry package-helper[9271]: [1603032849] unbound-checkconf[9273:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Oct 19 01:54:09 raspberry package-helper[9274]: [1603032849] unbound-checkconf[9276:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Oct 19 01:54:09 raspberry unbound[9277]: [1603032849] unbound[9277:0] error: Could not open /etc/unbound/unbound.conf: No such file or directory
Oct 19 01:54:09 raspberry unbound[9277]: [1603032849] unbound[9277:0] warning: Continuing with default config settings
Oct 19 01:54:09 raspberry unbound[9277]: [1603032849] unbound[9277:0] error: can't bind socket: Address already in use for ::1 port 53
Oct 19 01:54:09 raspberry unbound[9277]: [1603032849] unbound[9277:0] fatal error: could not open ports
Oct 19 01:54:09 raspberry systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 01:54:09 raspberry systemd[1]: unbound.service: Failed with result 'exit-code'.
Oct 19 01:54:09 raspberry systemd[1]: unbound.service: Scheduled restart job, restart counter is at 10.
Oct 19 01:54:09 raspberry systemd[1]: unbound.service: Start request repeated too quickly.
File still missing.
Could purge/uninstall unbound but then have to run the whole guide again.
Try create that file:
sudo nano /etc/unbound/unbound.conf
Paste below into that file, save/exit:
# Unbound configuration file for Debian.
# See the unbound.conf(5) man page.
# See /usr/share/doc/unbound/examples/unbound.conf for a commented
# reference config file.
# The following line includes additional configuration files from the
# /etc/unbound/unbound.conf.d directory.
include: "/etc/unbound/unbound.conf.d/*.conf"
Restart:
sudo service unbound restart
And status journals drill again:
systemctl --no-pager --full status unbound
journalctl --no-pager --full -u unbound
   Loaded: loaded (/lib/systemd/system/unbound.service; enabled; vendor preset:
enabled)
   Active: active (running) since Mon 2020-10-19 02:12:27 AEDT; 13s ago
     Docs: man:unbound(8)
  Process: 10813 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code
=exited, status=0/SUCCESS)
  Process: 10816 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_
update (code=exited, status=0/SUCCESS)
 Main PID: 10821 (unbound)
    Tasks: 1 (limit: 2065)
   CGroup: /system.slice/unbound.service
           └─10821 /usr/sbin/unbound -d
Oct 19 02:12:26 raspberry systemd[1]: Starting Unbound DNS server...
Oct 19 02:12:27 raspberry package-helper[10816]: /var/lib/unbound/root.key has c
ontent
Oct 19 02:12:27 raspberry package-helper[10816]: success: the anchor is ok
Oct 19 02:12:27 raspberry unbound[10821]: [10821:0] info: start of service (unbo
und 1.9.0).
Oct 19 02:12:27 raspberry systemd[1]: Started Unbound DNS server.
Oct 19 02:11:07 raspberry unbound[10611]: read /etc/unbound/unbound.conf failed:
 3 errors in configuration file
Oct 19 02:11:07 raspberry unbound[10611]: [1603033867] unbound[10611:0] fatal er
ror: Could not read config file: /etc/unbound/unbound.conf. Maybe try unbound -d
d, it stays on the commandline to see more errors, or unbound-checkconf
Oct 19 02:11:07 raspberry systemd[1]: unbound.service: Main process exited, code
Oct 19 02:11:07 raspberry systemd[1]: unbound.service: Failed with result 'exit-
code'.
Oct 19 02:11:07 raspberry systemd[1]: Failed to start Unbound DNS server.
Oct 19 02:11:07 raspberry systemd[1]: unbound.service: Service RestartSec=100ms
Oct 19 02:11:07 raspberry systemd[1]: unbound.service: Scheduled restart job, re
start counter is at 5.
Oct 19 02:11:07 raspberry systemd[1]: Stopped Unbound DNS server.
Oct 19 02:11:07 raspberry systemd[1]: unbound.service: Start request repeated to
o quickly.
code'.
Oct 19 02:12:21 raspberry systemd[1]: Starting Unbound DNS server...
Oct 19 02:12:21 raspberry package-helper[10701]: /var/lib/unbound/root.key does
not exist, copying from /usr/share/dns/root.key
Oct 19 02:12:22 raspberry package-helper[10701]: /var/lib/unbound/root.key has c
ontent
Oct 19 02:12:22 raspberry package-helper[10701]: success: the anchor is ok
Oct 19 02:12:22 raspberry unbound[10706]: [10706:0] info: start of service (unbo
und 1.9.0).
Oct 19 02:12:22 raspberry systemd[1]: Started Unbound DNS server.
Oct 19 02:12:26 raspberry unbound[10706]: [10706:0] info: service stopped (unbou
nd 1.9.0).
Oct 19 02:12:26 raspberry systemd[1]: Stopping Unbound DNS server...
Oct 19 02:12:26 raspberry systemd[1]: unbound.service: Succeeded.
Oct 19 02:12:26 raspberry systemd[1]: Stopped Unbound DNS server.
ontent
und 1.9.0).
seems to be working now.
Thanks for the help!!
I now need to continue with Pihole configuration.
Can you please refer me to a guide on how to use Unbound with DoT or DoH?
No sorry I cant.
I have no use for DoT or DoH.
Refer to Unbound using TLS - not working as recursive DNS server anymore? for a link to a 3rd party guide as well as related discussion.
Consider opening a new topic if you encounter errors when trying to make DoT and unbound work, or reach out to the guide's author.
by the way, running these commands:
dig sigfail.verteiltesysteme.net @127.0.0.1 -p 5335
dig sigok.verteiltesysteme.net @127.0.0.1 -p 5335
returned:
pi@raspberry:/etc/unbound $ dig sigfail.verteiltesysteme.net @127.0.0.1 -p 5335
; <<>> DiG 9.11.5-P4-5.1+deb10u2-Raspbian <<>> sigfail.verteiltesysteme.net @127
.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 47534
;sigfail.verteiltesysteme.net.  IN      A
sigfail.verteiltesysteme.net. 17 IN     A       134.91.78.139
;; Query time: 0 msec
;; WHEN: Mon Oct 19 02:18:54 AEDT 2020
;; MSG SIZE  rcvd: 73
pi@raspberry:/etc/unbound $ dig sigok.verteiltesysteme.net @127.0.0.1 -p 5335
; <<>> DiG 9.11.5-P4-5.1+deb10u2-Raspbian <<>> sigok.verteiltesysteme.net @127.0
.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 40678
;sigok.verteiltesysteme.net.    IN      A
sigok.verteiltesysteme.net. 60  IN      A       134.91.78.139
;; Query time: 255 msec
;; WHEN: Mon Oct 19 02:19:06 AEDT 2020
;; MSG SIZE  rcvd: 71
no difference.
DNS settings are:
No check on Use DNSSEC
and using Cloudflare DNS
No custom DNS
Ok seems more things are messed up somehow.
Try purge/uninstall unbound including config files:
sudo service unbound stop
sudo apt purge unbound
And run the guide again:
Seems that a lot of the issues I was experiencing were due to a faulty microSD card.
I replaced the microSD card and installed RPiOS, Pihole and Unbound and it seems to work without an issue now.
