Blacklist should be added shown 6 when adding the 7th, it never shows
Blacklist never get added
Are you referring to a blacklist entry - a local domain name added to your local blacklist?
Or, are you referring to a block list entry - a URL that leads to a public list of domains that you want your Pi-Hole to block?
From your debug log, given that you have six subscribed blocklists and 25 entries on your local blacklist, it appears that you are trying to add a block list.
Please walk us through the steps you are using to add this blocklist, along with the URL of the blocklist you are trying to add.
Trying to add the blacklist url, for the list of blacklist domains. The url I'm trying to add is: https://github.com/vincentkenny01/spotblock/blob/master/file1
However when I say I can't save any setting, such as changing listening interface in the web console, from all origins to only eth0, and saving, once the page reloads nothing has changed.
Your terminology is incorrect. You are trying to add a "block" list URL, not a "black" list.
As far as I can see, this is not a valid URL. Loading it results in a 404 error.
Let's take a look at the permissions in your /etc/pihole folder. What is the output of this command (you can copy and paste into a reply).
ls -lh /etc/pihole
[root@shawn-route ~]# ls -lh /etc/pihole
total 26M
-rwxrwxrwx 1 root root 313 Oct 10 18:02 adlists.list
-rwxrwxrwx 1 root root 3.2K Aug 2 01:33 adlists.list.old
-rwxrwxrwx 1 root root 720 Oct 7 12:50 black.list
-rwxrwxrwx 1 root root 720 Aug 13 10:13 blacklist.txt
-rwxrwxrwx 1 pihole pihole 0 Oct 11 05:00 dhcp.leases
-rwxrwxrwx 1 root root 596 Oct 2 15:05 dns-servers.conf
-rwxrwxrwx 1 root root 20 Oct 11 05:00 GitHubVersions
-rw-r--r-- 1 root root 2.6M Oct 5 20:18 gravity.list
-rwxrwxrwx 1 root root 6.3K Oct 2 15:06 install.log
-rw------- 1 root root 1.3M Oct 5 23:49 list.0.raw.githubusercontent.com.domains
-rw------- 1 root root 119K Oct 5 23:49 list.10.easylist.to.domains
-rw------- 1 root root 20K Oct 5 23:49 list.11.easylist.to.domains
-rw------- 1 root root 2.2M Oct 5 23:49 list.12.raw.githubusercontent.com.domains
-rw------- 1 root root 58K Jul 26 16:59 list.13.jasonhill.co.uk.domains
-rw------- 1 root root 1.7K Oct 5 23:49 list.14.raw.githubusercontent.com.domains
-rw------- 1 root root 283K Oct 5 23:49 list.15.raw.githubusercontent.com.domains
-rw------- 1 root root 158 Oct 5 23:49 list.16.raw.githubusercontent.com.domains
-rw------- 1 root root 283K Oct 5 23:49 list.17.raw.githubusercontent.com.domains
-rw------- 1 root root 59 Oct 5 23:49 list.18.raw.githubusercontent.com.domains
-rw------- 1 root root 56K Oct 5 23:49 list.19.v.firebog.net.domains
-rw------- 1 root root 582K Oct 5 23:49 list.1.mirror1.malwaredomains.com.domains
-rw------- 1 root root 13K Oct 5 23:49 list.20.raw.githubusercontent.com.domains
-rw------- 1 root root 6.6K Oct 5 23:49 list.21.raw.githubusercontent.com.domains
-rw------- 1 root root 2.0M Oct 5 23:49 list.22.raw.githubusercontent.com.domains
-rw------- 1 root root 19K Oct 5 23:49 list.23.raw.github.com.domains
-rw------- 1 root root 54K Oct 5 23:49 list.24.gist.githubusercontent.com.domains
-rw------- 1 root root 374K Oct 5 23:49 list.25.gitlab.com.domains
-rw------- 1 root root 4.9K Oct 5 23:49 list.26.gitlab.com.domains
-rw------- 1 root root 40K Oct 5 23:49 list.27.www.stopforumspam.com.domains
-rw------- 1 root root 470K Oct 5 23:49 list.28.v.firebog.net.domains
-rw------- 1 root root 67K Oct 5 23:49 list.29.www.squidblacklist.org.domains
-rwxrwxrwx 1 root root 624K Jul 23 17:32 list.2.sysctl.org.domains
-rw------- 1 root root 1.9K Oct 5 23:49 list.30.raw.githubusercontent.com.domains
-rw------- 1 root root 13K Oct 5 23:49 list.31.raw.githubusercontent.com.domains
-rw------- 1 root root 111K Oct 5 23:49 list.32.v.firebog.net.domains
-rw------- 1 root root 111K Oct 5 23:49 list.33.v.firebog.net.domains
-rw------- 1 root root 34K Oct 5 23:49 list.34.phishing.army.domains
-rw------- 1 root root 51K Oct 5 23:49 list.35.ransomwaretracker.abuse.ch.domains
-rw------- 1 root root 4.4K Oct 5 23:49 list.36.ransomwaretracker.abuse.ch.domains
-rw------- 1 root root 3.9K Oct 5 23:49 list.37.ransomwaretracker.abuse.ch.domains
-rw------- 1 root root 3.1K Oct 5 23:49 list.38.ransomwaretracker.abuse.ch.domains
-rw------- 1 root root 969 Oct 5 23:49 list.39.ransomwaretracker.abuse.ch.domains
-rwxrwxrwx 1 root root 613 Oct 2 15:06 list.3.s3.amazonaws.com.domains
-rw------- 1 root root 53 Oct 5 23:49 list.3.zeustracker.abuse.ch.domains
-rw------- 1 root root 330K Oct 5 23:49 list.40.v.firebog.net.domains
-rw------- 1 root root 68K Oct 5 23:49 list.41.raw.githubusercontent.com.domains
-rw------- 1 root root 2.9M Oct 5 23:49 list.42.www.squidblacklist.org.domains
-rw------- 1 root root 729K Sep 28 23:49 list.43.zerodot1.gitlab.io.domains
-rw------- 1 root root 14K Oct 5 23:49 list.44.adaway.org.domains
-rwxrwxrwx 1 root root 613 Jul 23 17:32 list.4.s3.amazonaws.com.domains
-rwxrwxrwx 1 root root 1.7M Oct 2 15:06 list.5.hosts-file.net.domains
-rwxrwxrwx 1 root root 43K Jul 23 17:33 list.5.s3.amazonaws.com.domains
-rwxrwxrwx 1 root root 1.7M Jul 23 17:33 list.6.hosts-file.net.domains
-rw------- 1 root root 363K Oct 5 23:49 list.7.easylist-downloads.adblockplus.org.domains
-rw------- 1 root root 432K Oct 5 23:49 list.8.someonewhocares.org.domains
-rw------- 1 root root 1.2M Oct 5 23:49 list.9.raw.githubusercontent.com.domains
-rwxrwxrwx 1 root root 2.6M Oct 5 20:18 list.preEventHorizon
-rwxrwxrwx 1 root root 20 Oct 11 13:00 localbranches
-rwxrwxrwx 1 root root 172 Oct 5 20:18 local.list
-rwxrwxrwx 1 root root 42 Oct 11 13:00 localversions
-rwxrwxrwx 1 root root 234 Oct 2 15:05 logrotate
-rwxrwxrwx 1 root root 2.3M Oct 2 15:05 macvendor.db
-rwxrwxrwx 1 root root 15 Oct 2 15:06 pihole-FTL.conf
-rw-r--r-- 1 pihole pihole 264K Oct 11 12:19 pihole-FTL.db
-rwxrwxrwx 1 root root 1 Oct 11 12:02 regex.list
-rwxrwxrwx 1 root root 3.1K Oct 10 17:56 rules.v4
-rwxrwxrwx 1 root root 456 Oct 10 18:03 setupVars.conf
-rw-r--r-- 1 root root 5.2K Oct 7 12:50 whitelist.txt
If you edit the blacklist file directly, are you able to add this domain (which you appear to have mis-spelled) to that file?
sudo nano /etc/pihole/blacklist.txt
Add the domain as a new line at the bottom, save, exit.
Then run pihole -g
to update gravity. And see if the new domain is in the web admin GUI under the blacklisted domains.
Done and yes, what about blockurl list and the permissions?
