Connect to my admin user interface on my web browser
I get the, "refused to connect sign and that this site can't be reached.
[β] lighttpd daemon is failed
What is the output from sudo systemctl status --full --no-pager lighttpd.service
pi@noads:~ $ man lighttpd
-f configfile
Load configuration file configfile.
-tt Test the configuration file for syntax errors, load and iniβ
tialize modules, and exit.
Try below and select repair:
pihole -r
If that doesnt fix, try purge the lighttpd
package, including config files:
sudo dpkg -P lighttpd
And re-install from apt
cache:
sudo apt install --reinstall lighttpd
And have Pi-hole configure lighttpd
by selecting repair:
pihole -r
Thank you very much for the quick reply I greatly appreciate it. Whenever i load the admin page now it just says 400 Bad Request in the top right corner of the page. Do i need to reinstall something else?
Thank you very much.
Try below:
EDIT: restart after the change:
sudo service lighttpd restart
That seemed to work.Thank you very much!!!
