Can access dashboard at pi.hole/admin
Cannot access at pi.hole/admin
Can access dashboard at my-ip-addreds/admin
Debug token is https://tricorder.pi-hole.net/m10fzs55xx
Some other info that may be relevant
pi@pi-hole:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@pi-hole:~ $ sudo service lighttpd status
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2019-11-13 19:35:23 GMT; 2min 36s ago
Process: 27866 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 27873 (lighttpd)
Memory: 9.3M
CGroup: /system.slice/lighttpd.service
├─27873 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
├─27883 /usr/bin/php-cgi
├─27884 /usr/bin/php-cgi
├─27885 /usr/bin/php-cgi
lines 1-11...skipping...
Memory: 9.3M
├─27886 /usr/bin/php-cgi
└─27887 /usr/bin/php-cgi
Nov 13 19:35:23 pi-hole systemd[1]: Starting Lighttpd Daemon...
Nov 13 19:35:23 pi-hole systemd[1]: Started Lighttpd Daemon.
Nov 13 19:36:58 pi-hole sudo[27927]: www-data : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Nov 13 19:36:58 pi-hole sudo[27927]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 13 19:36:59 pi-hole sudo[27927]: pam_unix(sudo:session): session closed for user root
pi@pi-hole:~ $ curl -I 127.0.0.1
HTTP/1.1 200 OK
Date: Wed, 13 Nov 2019 19:23:25 GMT
Server: lighttpd/1.4.53
Edited to correct my typo on CL resulting in false info
