Expected Behavior:
The admin panel loads
Actual Behavior:
The admin panel doesn't load, getting err_connection_refused
(also can't ssh, but that doesn't matter much to me)
Also, trying to access the admin panel through http://pi.hole just gives err_name_not_resolved
https://tricorder.pi-hole.net/mvj374wwsx
Your debug log shows a lot of stops and starts for Pi-hole's web server lighttpd
-rw-r--r-- 1 www-data www-data 1787 Jul 16 09:49 /var/log/lighttpd/error.log
-----head of error.log------
2021-07-16 08:03:13: (server.c.1488) server started (lighttpd/1.4.55)
2021-07-16 08:03:31: (server.c.1970) server stopped by UID = 0 PID = 1
2021-07-16 08:03:32: (server.c.1488) server started (lighttpd/1.4.55)
2021-07-16 08:21:37: (server.c.1970) server stopped by UID = 0 PID = 1
2021-07-16 08:21:38: (server.c.1488) server started (lighttpd/1.4.55)
2021-07-16 08:23:07: (server.c.1970) server stopped by UID = 0 PID = 1
Let's check your lighttpd
What's the ouput of:
sudo systemctl status --full --no-pager lighttpd.service
ok idk whats going on, but I went to bed and it started working again once I got up
here's the output though, it's the same as when it wasn't working
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-07-16 09:49:53 UTC; 9h ago
Process: 4611 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 4631 (lighttpd)
Tasks: 6 (limit: 9448)
Memory: 15.9M
CGroup: /system.slice/lighttpd.service
├─4631 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
├─4638 /usr/bin/php-cgi
├─4639 /usr/bin/php-cgi
├─4640 /usr/bin/php-cgi
├─4641 /usr/bin/php-cgi
└─4642 /usr/bin/php-cgi
Jul 16 09:49:53 networking systemd[1]: Started Lighttpd Daemon.
Jul 16 09:51:15 networking sudo[5222]: www-data : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Jul 16 09:51:15 networking sudo[5222]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 16 09:51:15 networking sudo[5222]: pam_unix(sudo:session): session closed for user root
Jul 16 09:51:15 networking sudo[5239]: www-data : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Jul 16 09:51:15 networking sudo[5239]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 16 09:51:15 networking sudo[5239]: pam_unix(sudo:session): session closed for user root
Jul 16 19:40:49 networking sudo[26028]: www-data : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Jul 16 19:40:49 networking sudo[26028]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 16 19:40:49 networking sudo[26028]: pam_unix(sudo:session): session closed for user root
system
Closed
August 6, 2021, 7:44pm
4
