can not disable pi-hole from web interface or change other settings
Being able to change settings of pi-hole from web-interface
settings (e.g. disabling pi-hole) are not changed (pi-hole still active as verified in the command line status), but the timer runs backwards and the UI changes
https://tricorder.pi-hole.net/6awmowf8ax
This is a follow up to a discussion un the sub-reddit pi-hole.
Original problem description:
I have pi-hole installed on a pi together with Hoobs, and all adds are blocked - working nicely.
But:
Even when I disable pi-hole, it is still blocking all ads (e.g. I can not access the sponsored links in a google search).
It says "Enable (0:03:01)" and is counting down, even after a reload.
It is a standard installation, as far as I know.
Also: I don't seem to be able to change the DNS server - it always goes back to OpenDNS?
I used the info on https://hoobs.org/knowledge-base/how-to-install-pi-hole-alongside-hoobs/ to install pi-hole in hoobs.
As stated there, I assume, it is a permission issue, as it works from the command line. Any suggestions, how I can fix this?
Please generate and upload a new debug log and post that token. I cannot find a debug log with the token you provided.
Here it is:
https://tricorder.pi-hole.net/kvs0y7k92h
As written in the other thread, you could disable pihole from the web interface and have a look in /var/log/lighttpd/error.log and /var/log/lighttpd/access.log for more info.
OK - error.log: nichts drin.
access.log nach ausführen von http://hoobs.local/admin/api.php?disable=300&auth=xxxxx
1589878875|hoobs.local|GET /admin/ HTTP/1.1|200|14346
1589878875|hoobs.local|GET /admin/style/vendor/ionicons-2.0.1/css/ionicons.min.css HTTP/1.1|200|8360
1589878875|hoobs.local|GET /admin/style/vendor/bootstrap/css/bootstrap.min.css HTTP/1.1|200|19896
1589878875|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/css/all.min.css HTTP/1.1|200|11633
1589878875|hoobs.local|GET /admin/style/pi-hole.css HTTP/1.1|200|1614
1589878875|hoobs.local|GET /admin/style/vendor/js-warn.css HTTP/1.1|200|553
1589878875|hoobs.local|GET /admin/style/vendor/AdminLTE.min.css HTTP/1.1|200|13719
1589878875|hoobs.local|GET /admin/style/vendor/daterangepicker.css HTTP/1.1|200|1606
1589878875|hoobs.local|GET /admin/scripts/pi-hole/js/header.js HTTP/1.1|200|293
1589878875|hoobs.local|GET /admin/scripts/vendor/jquery-ui.min.js HTTP/1.1|200|64483
1589878875|hoobs.local|GET /admin/style/vendor/skin-blue.min.css HTTP/1.1|200|733
1589878875|hoobs.local|GET /admin/style/vendor/bootstrap/js/bootstrap.min.js HTTP/1.1|200|9764
1589878875|hoobs.local|GET /admin/scripts/vendor/app.min.js HTTP/1.1|200|2868
1589878875|hoobs.local|GET /admin/scripts/vendor/jquery.dataTables.min.js HTTP/1.1|200|28013
1589878875|hoobs.local|GET /admin/scripts/vendor/dataTables.bootstrap.min.js HTTP/1.1|200|1058
1589878875|hoobs.local|GET /admin/scripts/pi-hole/js/index.js HTTP/1.1|200|7323
1589878875|hoobs.local|GET /admin/scripts/vendor/Chart.bundle.min.js HTTP/1.1|200|62602
1589878875|hoobs.local|GET /admin/scripts/pi-hole/js/footer.js HTTP/1.1|200|1844
1589878875|hoobs.local|GET /admin/style/vendor/dataTables.bootstrap.min.css HTTP/1.1|304|0
1589878875|hoobs.local|GET /admin/scripts/vendor/jquery.min.js HTTP/1.1|304|0
1589878875|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro.css HTTP/1.1|200|252
1589878875|hoobs.local|GET /admin/img/logo.svg HTTP/1.1|200|1649
1589878875|hoobs.local|GET /admin/img/donate.gif HTTP/1.1|200|3592
1589878875|hoobs.local|GET /admin/img/boxed-bg.jpg HTTP/1.1|200|123770
1589878876|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Regular.ttf HTTP/1.1|200|149972
1589878876|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878876|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-solid-900.woff2 HTTP/1.1|200|79100
1589878876|hoobs.local|GET /admin/api.php?overTimeData10mins HTTP/1.1|200|4543
1589878876|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Bold.ttf HTTP/1.1|200|148932
1589878876|hoobs.local|GET /admin/style/vendor/ionicons-2.0.1/fonts/ionicons.ttf?v=2.0.0 HTTP/1.1|200|188508
1589878876|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Semibold.ttf HTTP/1.1|200|149636
1589878876|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-brands-400.woff2 HTTP/1.1|200|74288
1589878876|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-regular-400.woff2 HTTP/1.1|200|14872
1589878876|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Light.ttf HTTP/1.1|200|150244
1589878876|hoobs.local|GET /admin/img/favicon.png HTTP/1.1|200|8675
1589878877|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878878|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878879|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878880|hoobs.local|GET /admin/index.php?login HTTP/1.1|200|14522
1589878880|hoobs.local|GET /admin/img/donate.gif HTTP/1.1|200|3592
1589878880|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Regular.ttf HTTP/1.1|200|149972
1589878880|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-brands-400.woff2 HTTP/1.1|200|74288
1589878880|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Semibold.ttf HTTP/1.1|200|149636
1589878880|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-solid-900.woff2 HTTP/1.1|200|79100
1589878880|hoobs.local|GET /admin/style/vendor/bootstrap/fonts/glyphicons-halflings-regular.woff2 HTTP/1.1|200|18028
1589878880|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Bold.ttf HTTP/1.1|200|148932
1589878880|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Light.ttf HTTP/1.1|200|150244
1589878880|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-regular-400.woff2 HTTP/1.1|200|14872
1589878886|hoobs.local|POST /admin/index.php?login HTTP/1.1|302|0
1589878886|hoobs.local|GET /admin/index.php HTTP/1.1|200|26335
1589878886|hoobs.local|GET /admin/img/donate.gif HTTP/1.1|200|3592
1589878886|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878886|hoobs.local|GET /admin/api.php?overTimeData10mins HTTP/1.1|200|4543
1589878886|hoobs.local|GET /admin/api.php?getQueryTypes HTTP/1.1|200|105
1589878886|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Semibold.ttf HTTP/1.1|200|149636
1589878886|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Regular.ttf HTTP/1.1|200|149972
1589878886|hoobs.local|GET /admin/api.php?getForwardDestinations HTTP/1.1|200|163
1589878886|hoobs.local|GET /admin/api.php?overTimeDataClients&getClientNames HTTP/1.1|200|3301
1589878886|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-solid-900.woff2 HTTP/1.1|200|79100
1589878886|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878886|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-brands-400.woff2 HTTP/1.1|200|74288
1589878886|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Bold.ttf HTTP/1.1|200|148932
1589878886|hoobs.local|GET /admin/style/vendor/ionicons-2.0.1/fonts/ionicons.ttf?v=2.0.0 HTTP/1.1|200|188508
1589878886|hoobs.local|GET /admin/style/vendor/font-awesome-5.6.3/webfonts/fa-regular-400.woff2 HTTP/1.1|200|14872
1589878886|hoobs.local|GET /admin/style/vendor/SourceSansPro/SourceSansPro-Light.ttf HTTP/1.1|200|150244
1589878886|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878887|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878888|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878889|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878890|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878891|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878892|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878892|hoobs.local|GET /admin/api.php?disable=10&token=%2BEBmGknFbI%2FIfgCFrAXvvbF35UjVkGUYk38ZMo%2F948Q%3D HTTP/1.1|200|21
1589878893|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878894|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878895|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878896|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878896|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878896|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878897|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878898|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878899|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878900|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878901|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878902|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878903|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878904|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878905|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878906|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878907|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878907|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878908|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878909|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878910|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878911|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878912|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878913|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878914|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878915|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878916|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878917|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878917|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878917|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878918|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878919|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878920|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878921|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878922|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878923|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878925|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878925|hoobs.local|GET /admin/api.php?disable=300&token=%2BEBmGknFbI%2FIfgCFrAXvvbF35UjVkGUYk38ZMo%2F948Q%3D HTTP/1.1|200|21
1589878926|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878927|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878927|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878927|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878928|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878929|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878930|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878931|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878932|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878933|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878934|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878936|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878937|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878938|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878938|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878938|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878939|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878940|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878942|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878945|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878946|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878947|hoobs.local|GET /admin/api.php?getQueryTypes HTTP/1.1|200|105
1589878947|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878947|hoobs.local|GET /admin/api.php?getForwardDestinations HTTP/1.1|200|162
1589878949|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878949|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878949|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878952|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878954|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878956|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878957|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878958|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878959|hoobs.local|GET /admin/api.php?enable&token=%2BEBmGknFbI%2FIfgCFrAXvvbF35UjVkGUYk38ZMo%2F948Q%3D HTTP/1.1|200|20
1589878959|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878959|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878960|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878960|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878961|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878962|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878963|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878964|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878965|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878966|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878967|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878968|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878970|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878970|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878970|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878975|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878983|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878983|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589878983|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878987|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878988|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878992|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878996|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589878997|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589878997|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879002|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879008|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879008|hoobs.local|GET /admin/api.php?getForwardDestinations HTTP/1.1|200|163
1589879008|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879008|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879008|hoobs.local|GET /admin/api.php?getQueryTypes HTTP/1.1|200|105
1589879013|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879014|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879015|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879016|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879017|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879018|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879018|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879018|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879018|hoobs.local|GET /admin/api.php?disable=300&token=%2BEBmGknFbI%2FIfgCFrAXvvbF35UjVkGUYk38ZMo%2F948Q%3D HTTP/1.1|200|21
1589879019|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879020|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879021|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879023|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879024|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879025|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879026|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879027|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879028|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879028|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879028|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879029|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879030|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879031|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879032|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879033|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879034|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879035|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879036|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879037|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879038|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879038|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879038|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879039|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879041|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879042|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879043|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879044|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879045|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879046|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879047|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879048|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879048|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879048|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879049|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879050|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879051|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879052|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879053|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879054|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879055|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879056|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879057|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879058|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879059|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1120
1589879059|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|592
1589879059|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879060|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879061|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879062|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879063|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879065|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879069|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879069|hoobs.local|GET /admin/api.php?getForwardDestinations HTTP/1.1|200|163
1589879069|hoobs.local|GET /admin/api.php?getQueryTypes HTTP/1.1|200|105
1589879069|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879069|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879074|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879079|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879079|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879080|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879083|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879084|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879090|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879090|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879090|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879094|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879096|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879100|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879100|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879100|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879105|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879110|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879111|hoobs.local|GET /admin/api.php?summaryRaw&topItems HTTP/1.1|200|1121
1589879111|hoobs.local|GET /admin/api.php?summaryRaw&getQuerySources&topClientsBlocked HTTP/1.1|200|593
1589879112|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879115|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879116|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879119|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879123|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879125|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879128|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879129|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879130|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879132|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879133|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879134|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879136|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879137|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879138|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879139|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879146|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879148|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879149|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879151|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879153|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879154|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879155|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879160|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879161|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879166|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879168|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879171|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879172|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879174|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879177|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879178|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879179|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879181|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879182|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879183|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879185|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879186|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879187|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879188|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879190|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879192|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879193|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879196|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879198|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879199|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879202|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879203|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879207|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879210|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879212|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879215|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879216|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879217|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879221|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879222|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879228|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879231|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879233|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879236|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879238|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879241|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879241|hoobs.local|GET /admin/api.php?disable=300&auth=23c0bd7df5cfb10c77daf6652ed0de00123818b2d134e136a75cfc5489cde1c6 HTTP/1.1|200|21
1589879241|hoobs.local|GET /favicon.ico HTTP/1.1|200|568
1589879243|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879246|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879248|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879251|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879253|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
root@hoobs:/var/log/lighttpd# tail -f  access.log
1589879258|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879264|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879268|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879269|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879270|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879273|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879275|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879279|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879279|hoobs.local|GET /admin/api.php?disable=300&auth=23c0bd7df5cfb10c77daf6652ed0de00123818b2d134e136a75cfc5489cde1c6 HTTP/1.1|200|21
1589879280|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879283|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879284|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879289|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879295|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879300|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
1589879302|hoobs.local|GET /admin/api.php?summary HTTP/1.1|200|524
Just upgraded to 5.0, and still the same.
I have no further idea where to look. The moderators and devs might be able to sort it out.
