Hello Forum,
I have 3 Pi-Holes running on servers that receive their requests via nginx using DoT or DoH.
I've noticed that, in very rare cases, DNS requests are answered from the cache.
A large number of them are forwarded to the upstream servers.
I’ve configured Quad9, Cloudflare, and others as upstream servers—no Unbound.
The three Pi-Holes are running in Docker containers.
Here’s the Compose file I’m using:
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "30000:53/tcp"
- "30000:53/udp"
# - "30001:67/udp"
- "30002:80/tcp"
- "30003:443/tcp"
environment:
TZ: 'Europe/Berlin'
# WEBPASSWORD: 'set a secure password here or it will be random'
volumes:
- './etc-pihole/:/etc/pihole/'
# - './etc-dnsmasq.d/:/etc/dnsmasq.d/'
dns:
# - 127.0.0.1
- 9.9.9.9
- 1.1.1.1
# Recommended but not required (DHCP needs NET_ADMIN)
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
cap_add:
- NET_ADMIN
restart: unless-stopped
When I send a query to one of the three Pi-Holes, it gets forwarded right away. That works as expected.
If I make the same request again, it gets forwarded again, even though the cache should actually know the answer.
I wrote a little Bash script that fires off 300 DNS requests at once.
The cache is almost never used.
Even when I run it once every 2 minutes.
However, in the system stats, you can see that “Active cache records” goes up, and “Total cache insertions” does as well.
If i set a static local dns record, the cache works and i see the icon for cache in the query log.
I have two other Pi-Holes on my home network, one running in an LXC container and the other directly on a Raspberry Pi.
They work without any issues and use the cache much more often.
All Pi-Holes use the same blocklists and allowlists.
Blocking works fine too, only cache in the docker-holes not.
Is there a bug here?
