Habe eine Blockliste hinzugefügt. Auf dem Dashboard unter Blocked Domains werden die Links in der Lister aber nicht hizugezählt.
After you added the blocklist, did you select "save" or "save and update" on the web admin page?
Save and update
What is the output of the following commands from the Pi terminal:
cat /etc/pihole/adlists.list
pihole -g -f
[✓] Deleting existing list cache
[i] Target: raw.githubusercontent.com (hosts)
[i] Target: mirror1.malwaredomains.com (justdomains)
[i] Target: sysctl.org (hosts)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[✗] Status: s3.amazonaws.com is blocked by https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts. Using DNS on 208.67.222.222 to download https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
[i] Target: s3.amazonaws.com (simple_malvertising.txt)
[✗] Status: s3.amazonaws.com is blocked by https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts. Using DNS on 208.67.222.222 to download https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt
[i] Target: raw.githubusercontent.com (url-lists.txt)
[i] Target: v.firebog.net (Easyprivacy.txt)
[i] Target: v.firebog.net (Prigent-Ads.txt)
[i] Target: gitlab.com (notrack-blocklist.txt)
[i] Target: raw.githubusercontent.com (adservers.txt)
[i] Target: www.squidblacklist.org (dg-ads.acl)
[i] Target: raw.githubusercontent.com (list)
[i] Target: raw.githubusercontent.com (list2)
[i] Target: raw.githubusercontent.com (list3)
[i] Target: raw.githubusercontent.com (list4)
[✓] Format: URL
[i] Target: raw.githubusercontent.com (list5)
[i] Target: v.firebog.net (Easylist.txt)
[i] Target: v.firebog.net (AdguardDNS.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[✗] Status: s3.amazonaws.com is blocked by . Using DNS on 208.67.222.222 to download http://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
[i] Target: pgl.yoyo.org (serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext)
[i] Target: raw.githubusercontent.com (list6)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: adaway.org (hosts.txt)
[✗] Status: s3.amazonaws.com is blocked by . Using DNS on 208.67.222.222 to download https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
[i] Target: raw.githubusercontent.com (android-tracking.txt)
[✓] Consolidating blocklists
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 520700
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 406530
[i] Number of whitelisted domains: 1
[i] Number of blacklisted domains: 0
[i] Number of regex filters: 13
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] Force-reloading DNS service
[✓] DNS service is running
It looks like all the lists loaded and were combined into gravity. What is the problem you see?
I added some new Lists but on the Dashboard in the red box "Domains on Blocklist" the number not changed. I dont know whether it accepts the list or it don't accept it. So the Domains don't get blocked.
What was the output of this command?
https://raw.githubusercontent.com/HorusTeknoloji/TR-PhishingList/master/url-lists.txt
https://v.firebog.net/hosts/Easyprivacy.txt
https://v.firebog.net/hosts/Prigent-Ads.txt
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-blocklist.txt
https://raw.githubusercontent.com/jdlingyu/ad-wars/master/hosts
https://raw.githubusercontent.com/bigdargon/hostsVN/master/hosts
https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt
http://www.squidblacklist.org/downloads/dg-ads.acl
https://raw.githubusercontent.com/mar4in/PiholeListe/master/list
https://raw.githubusercontent.com/mar4in/PiholeListe/master/list2
https://raw.githubusercontent.com/mar4in/PiholeListe/master/list3
https://raw.githubusercontent.com/mar4in/PiholeListe/master/list4
https://raw.githubusercontent.com/mar4in/PiholeListe/master/list5
https://v.firebog.net/hosts/Easylist.txt
https://v.firebog.net/hosts/AdguardDNS.txt
https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext
https://raw.githubusercontent.com/mar4in/PiholeListe/master/list6
https://adaway.org/hosts.txt
https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/android-tracking.txt
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-malware.txt
https://gist.githubusercontent.com/anudeepND/adac7982307fec6ee23605e281a57f1a/raw/5b8582b906a9497624c3f3187a49ebc23a9cf2fb/Test.txt
Ich hatte ein ähnliches Problem, bei mir lag es an der Stromversorgung. Mein pi hat einfach zu wenig Saft von dem Router via USB erhalten, sodass ich diesen dann an eine externe Adpaterstromlösung anschloss. Danach hat alles funktioniert. Beim Schreibprozess der Listen ist die Stromversorgung nicht ausreichend gewesen. Keine Ahnung, ob der pi bei Dir auch nur via USB mit ACDC versorgt wird.
When I load the blocklists you have presented, using latest Pi-Hole master on a Pi Zero running Buster, this is the result of rebuilding gravity:
[✓] Format: URL
[✗] Format: Adblock (list type not supported)
[i] Target: gitlab.com (notrack-malware.txt)
[i] Target: gist.githubusercontent.com (Test.txt)
[i] Number of domains being pulled in by gravity: 503993
[i] Number of unique domains trapped in the Event Horizon: 399158
[i] Number of whitelisted domains: 195
[i] Number of blacklisted domains: 5
[i] Number of regex filters: 3
