That's correct. You can use any database editor that supports sqlite3 databases or use the sqlite3 CLI to achieve this or write a simply python script like
import sqlite3
# Connect to the database
db = sqlite3.connect('/etc/pihole/gravity.db')
# Instantiate a cursor object
cur = db.cursor()
# Define regex filters to be added in this file
domains = [('abc'),('def'),('fgh')]
# Alternatively, read them from a file
with open('regex.list', 'r') as f:
domains = f.read().splitlines()
# Generator for domains
def domain():
for c in domains:
yield (c,)
# Can be used to remove all currently enabled black regex
# cur.execute('DELETE FROM domainlist WHERE type = 3')
# Add (or change to black regex if already existing) regex filters from list
cur.executemany('INSERT OR REPLACE INTO domainlist (domain, type) VALUES (?, 3)', domain())
# List all black regex
cur.execute('SELECT domain FROM domainlist WHERE type = 3')
results = cur.fetchall()
for row in results:
print(row[0])
# Commit changes to the database
db.commit()
db.close()
Run it using
sudo -u pihole python3 import-regex.py
to ensure proper permissions for the database.
Note that, initially, we imported the legacy files whenever they were there instead of only when a new database is created during the upgrade v4 -> v5. What do you think?
