Problem with Beta 5.0:
I've recently blacklisted 3 Domains. Today i updated the pihole-beta.
Now the blacklist is empty, but according to the Query Log this domain is still blocked.
Have a look in Group Management/Domains. Do you see the domains there?
What is the domain in question? Also, please send us the token generated by
Tools > Generate Debug Log
No. ANd adding to that: Group Management/Domains is empty as well
That domain is shown as blocked on your Pi-hole debug log. What is the output of this command from the Pi terminal and from the client that is able to load the domain?
nslookup spectrum.s3.amazonaws.com
Sure:
Server: 127.0.0.1
Address: 127.0.0.1#53Name: spectrum.s3.amazonaws.com
Address: 0.0.0.0
Address: ::
But thats not the issue, my issue is with the WebUI
Please post a screen capture of what you see on the Web GUI blacklist screen. You can paste the graphic directly into a reply.
Ok, small addendum:
These pages work if access the pi using its ip-adress. I've configured apache on another system as proxy for a domain, everything works but this is broken. Can i add my domain somehow to allow access?
(This happend while using the domain.
Ah, okay, using a different web server as a proxy is not supported. However, I'm pretty sure you're not the first one doing something like this. Maybe someone from the community can give helpful advise.
I still consider this a bug.
Its neither mentioned anywhere in the WebUI nor is it a thing which can be configured in the webui.
