Using a running NGINX fully updated with php7.4
adding an url (google.nl) to the block list using the admin panel
Error, something went wrong!
same with the whitelist
You can directly add domains to the white or blacklist from the terminal. From man pihole on the terminal:
-w, whitelist [options] [<domain1> <domain2 ...>]
Adds or removes specified domain or domains to the Whitelist
-b, blacklist [options] [<domain1> <domain2 ...>]
Adds or removes specified domain or domains to the blacklist
url and domain is completely correct. sorry for the typo. I'm gonna try the unofficial user guide for " The php7.3-sqlite3 package must be installed otherwise Networking and Querying will throw an error that it can't access the database."
Than sounds plausible for some functions not working
