Hi
I used Pi-Hole for quite a while and decided to move it to my synology nas running in a docker container.
I use the latest pihole/pihole by diginc and it works perfect.
On my raspberry I allready had a custom conf file for dnsmasq to add conditional forwarder for 2 specifif domains. This worked flawlessly. However when I try the same with the docker image dnsmasq won't start because the config checker says "bad option at line 1"
Line one of /etc/dnsmasq.d/05.custom.conf actually contains:
server=/mydomain.ch/192.168.1.1
server=/my2domain.ch/192.168.1.1
What could be wrong with this config?
Thx a lot
regards,
Doemer
