Assigning a fixed address to smart plugs results in "Advanced settings present" error
I have several Meross MSS315 smart plugs that are working perfectly well but I cannot give them a fixed IP address.
They appear in the "Currently active DHCP leases" list albeit minus a hostname and client ID, and trying to copy these into the Static DHCP configuration results in an "advanced settings present error. Can anyone please advise how I get around this ? These are the only devices I have had an issue with on an established (several years old) installation with approx. 25 - 30 other devices all happily residing on their fixed addresses.
Copying a device from the "Currently active DHCP leases" to the "Static DHCP configuration" should result in the device being entered into the table where it can be edited.
"Advanced settings present in line..." errors for each device.
https://tricorder.pi.hole.net/0KcEDGsF
Thanks, everyone.
Hi All,
Thanks to everyone who took a look. I worked it out for myself once I realised that I could just enter the details manually in the advanced settings "terminal" window. It took me a while to realise that it was editable.
Just a note:
There are no errors in your screenshot, just a notification showing the lines contain "advanced" settings.
The old interface allowed only 3 fields (MAC Address, IP and hostname).
Now, the new interface allows many advanced settings, but they cannot be displayed on the table, when present, so the "Advanced settings ..." notice is shown.
