instead of lighttpd
Using pi-hole in a docker container from this repository, Pi-hole v5.8.1, FTL v5.13, Web Interface v5.10.1 on a raspberry pi. /etc/pihole/pihole-FTL.conf contains
PRIVACYLEVEL=0
BLOCK_ICLOUD_PR=false
REPLY_ADDR4=10.0.0.2
But when I have iCloud private relay enabled, ads are not blocked. nslookup of the relevant domains shows
○ nslookup mask-h2.icloud.com
Server: 10.0.0.1
Address: 10.0.0.1#53
** server can't find mask-h2.icloud.com: NXDOMAIN
○ nslookup mask.icloud.com
Server: 10.0.0.1
** server can't find mask.icloud.com: NXDOMAIN
Ads should be blocked when using iCloud Private Relay, nslookup should return some sort of non-authoritative answer.
Ads are not blocked, nslookup returns an NXDOMAIN response.
Debug token: https://tricorder.pi-hole.net/IeBsG9Mx/
