After installing the pihole docker container i expect to be able to reach the web admin on /admin. there is another pihole running in the network so pi.hole/admin goes to that pihole.
Reason i want to is i want to use 1 for the main LAN and 1 for my IoT devices. The one for IoT is running in the same network as the IoT LAN/WLAN segment/VLAN
The host is a ubuntu 18 machine.
The page just says "unable to connect" (firefox).
I have removed the container/config and started over a few times. But the docker container seems to be restarting several times in a row that is the error i get back when i try to remove it for example
Not sure how to add this from the docker. Is there a way to reach the container and be able to perform commands?
