Please ensure that you are running the latest version of the beta code. Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Sorry, this thread entirely slipped my attention somehow.
Not sure what is going on here. There is clearly a bug somewhere. I guess it is related to deep CNAME inspections which was the only major change to the internal machinery that could break things at such a fundamental level. I put it on my ToDo list, so I'll be back at some point!
@hammerhead8599 I tried to locate what might be causing this but wasn't able to find any suspicious code that could cause it. Do you also see negative numbers in the Top Blocked Domains table on the dashboard?
Yes, that'd be appreciated. This more eyes we have on this issue, the better. This fix should work, but the negative numbers only appeared over a longer period of time and I usually cannot afford running FTL very long on the same branch as I'm hopping from branch to branch while coding new stuff, tweaks and potentially other fixes.
