instead of lighttpd
_ [This is the latest version of pihole acquired via pihole up
it is running on a rasberryPi 3 32GB, with only 14% disk space used, maximum directory use 21%
PiHole is the only app I have running on this rasberry.
This stopped working in the last week between updates.
All piservices report healthy
I have cleared my browser cache and tried from multiple browsers
I expect that when I launch my admin console that the dashboard will populate just about instantly...]_
[At the moment it never loads, even after updating the RasberryPi OS and Pihole itself. ]
[bsooccgz9l]
