Additional setting needed
I have been using log-queries=extra, in order to identify all log lines, associated to a query, but it doesn't appear to be possible to change the default line in /etc/pihole/dnsmasq.conf
extra toml configuration entry ?
PR has been merged into development-v6
@DL6ER , @yubiuser
doesn't look good,
tried:
  • stop FTL, change toml, start FTL
  • change via web interface (screen doesn't reload after change)
result, both methods...
but commented out, in /etc/pihole/dnsmasq.conf
# Enable query logging
#log-queries=extra
log-async
edit
to clarify
unchecked (disabled) -> dnsmasq needs "log-queries"
checked (enabled) -> dnsmasq needs "log-queries=extra"
/edit
Yes, there is a typo in the code that adds the new line but falsely comments it out. Will be fixed by
Should work now, please update
