It would be great to be able to block MAC addresses directly from the web interface.
You could block out specific devices out of your network much faster / easier that way.
Good idea - You feature request is a subset of this feature request: DHCP Web Settings
It would be beneficial to close this one and add your support to the more encompassing request.
Hello
The Web interface does not contain a DHCP option to deny a host on the internal network.
My goal is to force a host (orange box) to use DHCP from my Orange router (ISP) because it blocks the use of the TV if it goes through another DHCP (pi-hole) which happens sometimes when renewing DHCP bay.
Thank you.
For now you can make a custom dnsmasq config in /etc/dnsmasq.d/
to do this.
I find this, if I add it in the file /etc/dnsmasq.d/02-pihole-dhcp.conf it will it pose a problem in the operation of pi-hole?
class "black-hole" {
match substring (hardware, 1, 6);
# deny booting;
ignore booting;
subclass "black-hole" 00:12:ba:1d:c1:b7;
Otherwise how to proceed?
Thank you
Put it in a new file, as Pi-hole files could be overwritten at any point.
Where did you find that config? It does not look like a dnsmasq config.
I found this config here "networking - How to ignore a set of Mac addresses in dhcpd.conf? - Server Fault".
How can I proceed?
Thank you.
That is not a dnsmasq config. That is for /etc/dhcpcd.conf
