This is on a fresh install. Let me know if I can provide more information
I should be able to see the console
I get a 403 forbidden
7zelkjo2rl
polson55:
7zelkjo2rl
The /etc/lighttpd/lighttpd.conf
file that is supplied by Pi-hole (pi-hole/advanced/lighttpd.conf.debian at master · pi-hole/pi-hole · GitHub ) was not copied over. The existing lighttpd.conf
file appears to the the stock version.
Looks like the same issue as this one:
opened 05:36PM - 10 Jun 19 UTC
closed 07:25PM - 10 May 20 UTC
Bug: Confirmed
Fixed in next release
**In raising this issue, I confirm the following:** `{please fill the checkboxes… , e.g: [X]}`
- [x] I have read and understood the [contributors guide](https://github.com/pi-hole/pi-hole/blob/master/CONTRIBUTING.md).
- [x] The issue I am reporting can be *replicated*.
- [x] The issue I am reporting isn't a duplicate (see [FAQs](https://github.com/pi-hole/pi-hole/wiki/FAQs), [closed issues](https://github.com/pi-hole/pi-hole/issues?utf8=%E2%9C%93&q=is%3Aissue%20is%3Aclosed%20), and [open issues](https://github.com/pi-hole/pi-hole/issues)).
**How familiar are you with the the source code relevant to this issue?:**
`0`
**Expected behaviour:**
Uninstall Pi-hole, and reinstall, the web admin area should accessible
**Actual behaviour:**
After re-install, the web admin area will not allow access. Error 403 - Unauthorized.
**Steps to reproduce:**
`pihole uninstall` and choose the option to remove all dependencies
Try to re-install and access the web / admin
**Debug token provided by [uploading `pihole -d` log](https://discourse.pi-hole.net/t/the-pihole-command-with-examples/738#debug):**
N/A
**Troubleshooting undertaken, and/or other relevant information:**
Tried re-installing several times, switching branches, `pihole -r` for repair and reconfigure, all to no avail.
Ended up re-imaging Raspbian and the fresh install seemed to do the trick. My Pi is now working as expected so unfortunately I can't give you further debug information at this time.
I am reporting this as I have noticed someone on Reddit also had the same experience after having tried to re-install Pi-hole.
On the dev branch, in case that makes any differences to the install / uninstall process.
I was able to fix by reinstalling lighttpd. I uninstalled and reinstalled a previous pihole installation to fix a different issue. I think the uninstall does not work correctly.
system
Closed
September 7, 2019, 5:11pm
4
