Use the teleporter and check whats in the zip file:
Oops, I believe it used to be a .zip
Now its .tar.gz
To unzip:
tar -xzf pi-hole-teleporter_2019-05-20_02-19-15.tar.gz
Did you try apt --fix-broken install
like the output requested?
Yes, several times.
The following additional packages will be installed:
libc6 libc6-dev
Suggested packages:
glibc-doc
libc6-dev
The following packages will be upgraded:
libc6
1 upgraded, 1 newly installed, 0 to remove and 61 not upgraded.
Need to get 0 B/4,281 kB of archives.
After this operation, 11.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Reading changelogs... Done
debconf: Perl may be unconfigured (Unrecognized character \xD2; marked by <-- HERE after DEXpO<-- HERE near column 6 at /usr/share/perl/5.24/Text/Tabs.pm line 6.
Compilation failed in require at /usr/share/perl/5.24/Text/Wrap.pm line 35.
BEGIN failed--compilation aborted at /usr/share/perl/5.24/Text/Wrap.pm line 35.
Compilation failed in require at /usr/share/perl5/Debconf/Template.pm line 10.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Template.pm line 10.
Compilation failed in require at /usr/share/perl5/Debconf/Question.pm line 8.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Question.pm line 8.
Compilation failed in require at /usr/share/perl5/Debconf/Config.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Config.pm line 7.
Compilation failed in require at /usr/share/perl5/Debconf/Log.pm line 10.
Compilation failed in require at (eval 1) line 4.
BEGIN failed--compilation aborted at (eval 1) line 4.
) -- aborting
(Reading database ... 35631 files and directories currently installed.)
Preparing to unpack .../libc6_2.24-11+deb9u4_armhf.deb ...
Compilation failed in require at /usr/share/perl5/Debconf/Db.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Db.pm line 7.
Compilation failed in require at /usr/share/debconf/frontend line 6.
BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 6.
dpkg: error processing archive /var/cache/apt/archives/libc6_2.24-11+deb9u4_armhf.deb (--unpack):
subprocess new pre-installation script returned error exit status 255
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
There is either filesystem corruption or the file listed /usr/share/perl/5.24/Text/Tabs.pm
has been modified. I don't think this is an easily solved issue and one that is not caused by the Pi-hole software or installer. You most likely will have to format and try again.
