Hi Everyone. I've been running Pihole from my Synology NAS a little over a month. I've since setup a Raspberry 4 with Pihole and have it running via wifi. The stats on the second pihole are lower but I attribute that to the first one catching things first.
I turned off the main one to check the wireless pihole to see how it was doing. Now When I set it up, I copied the block list from the Synology pihole to the raspbery one. However it doesn't seem to be blocking sites that the synology one is.
IS there something I'm not catching? I do have both Piholes set with a static IP on the router. TIA
